Results 1 to 4 of 4
Thread: Turning on E38 Fuel Pump
    Feb 2006
    Default Turning on E38 Fuel Pump
    The solution for this will probably come after i need it, but im tring to empty my fuel tank of fuel on a ve commodore. using the dvt controls the pump will only turn on and pump for about 5~10 seconds.
    it's taking me ages to fill the jerry can. (changing fuel tank over)
    it doesnt matter what % i use.
    WIth the ls1 computers you turn the pump on and it stays on....
    Mar 2008
    i bridge the relay at LH kick panel with a fused jump wire.
    Lifetime Member oztracktuning's Avatar
    Nov 2005
    Its cant be done with a VE that way Trecool, i tried it at Heathcote and in the end we had to just drive to get rid of the fuel. The worst i could average was 33L/100km.
    Oztrack
    EFILive Tuning Consultant
    Worldwide Remote Tuning Service
    2006 NSW Super Street Drag Racing Champion
    www.oztrack.com.au
    Lifetime Member hymey's Avatar
    Jan 2008
    +1 bridge the relay in LHS kick panel with a large paper clip ie bypass the switching source,drain it via the JIC fitting on the fuel rail.
  1. fuel pump control
    By THEFERMANATOR in forum Duramax LB7
    Last Post: August 9th, 2013, 06:13 AM
  2. which walbro fuel pump
    By limited cv8r in forum General (Petrol, Gas, Ethanol)
    Last Post: January 22nd, 2009, 03:42 AM
  3. Fuel Pressure with a Walbro pump?
    By BowlingSS in forum Gen III V8 Specific
    Last Post: January 13th, 2008, 03:11 AM
  4. Fuel Pump Voltage
    By SV8346 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 15th, 2007, 06:18 PM
  5. fuel pump upgrade
    By ZL1Killa in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 21st, 2006, 11:58 PM
