I was trying to setup to independent fans on for cooling on pin 42 and the other on 33 for intercooler heat exchanger. The one on pin 42 works fine for cooling the engine. The one on pin 33 Fan 2 won't turn on based on etc. I set it lower than fan 1. The car is a s-10 2002 4x4. I have verified the fan output is set via G0106 table, I can turn it on and off with dvt but just won't come on with etc. Any help guys?
Kurt
