Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: flashscan not recognized
    Oct 2007
    Default flashscan not recognized
    my flashscan v2 doesnt work anymore on my laptop. All i get is the windows message "usb device not recognized" it worked on my laptop 3 days ago. Ive tried to hook it up to two different laptops, two different cars, changed usb cables and still the same message. also tried to reset flashscan device to reset its settings still same. the flashscan device does power on and am able to navigate tru the menus. what could be going on?
    You will have to reinstall the USB driver...
    Try this: http://www.fishtuning.com/downloads/...and_I_cant.pdf
    Oct 2007
    i already tried what it said on that document. my problem is that as soon as I plug in the usb cable to the device it says "one of the usb devices attached to this computer has malfunctioned. I tried it on two different computers..
    Oct 2007
    looks like the usb6b1 chip is blown, got it shipped IRA@fishtuning yesterday. hopefully i will have it back soon. I was just gonna flash the tune after a cam install to my friends trans am when this happened.
    Mar 2008
    Quote Originally Posted by blazinblue View Post
    mine is doing the same thing,worked just fine and now v2 and kingston both
    usb units are not recognized,says that drivers are not loaded and when you
    try to update,says most updated drivers are installed.It works fine on other
    PC's
    I pm'd Tech Support.
    Quote Originally Posted by zacksfoam View Post
    ...and now v2 and kingston both
    usb units are not recognized,...
    What is "kingston" that you refer to?
    Nov 2006
    PC's
    It sounds like there is a problem with the USB port on your PC.
    A USB flash drive?
    LC-1 WBO2
    Lifetime Member Doc's Avatar
    Oct 2005
    A kingston usb to serial converter is my guess?
    www.efialchemy.com
    www.greatamericancarwar.com
    Mar 2008
    Kingston is my flash drive [8GB] that I store my tunes on.Running the FTDI
    uninstaller has error in file C:\windows\system32\ftcun2k.ini all of them
    [4] have error in file and nothing changed ,plug in V2 USB Device Not Recognized pops up
  1. flashscan V2 not recognized
    By charlie b in forum FlashScan V2
    Last Post: August 23rd, 2009, 09:45 AM
  2. V2-device not recognized
    By zacksfoam in forum FlashScan V2
    Last Post: August 14th, 2009, 06:56 PM
  3. K Engine not recognized
    By Lennart in forum E37, E38 & E67 PFI ECM's
    Last Post: February 7th, 2008, 01:27 PM
  4. When will FlashScan do this
    By Dirk Diggler in forum Lounge
    Last Post: December 28th, 2006, 09:48 AM
