Results 1 to 9 of 9
Thread: Current Gear and Oil Temp
    Apr 2009
    Default Current Gear and Oil Temp
    Oil Temp is not selectable. Would like to monitor this but how do you get it in? It's built into the factory cars so I would think you wouldn't need an external feed to monitor this.
    I searched around and found a txt formula for calculated box ratio that let me select it in v7.5 after entering it into calc_pids.txt, but how would I get that into b8.1 bbl?
    #Units Low High Fmt Expression
    *CLC-00-062
    None -4.0 4.0 .3 "{SAE.RPM} / {SAE.VSS.mph} / 336.135 / 3.29 * 24.86"
    #Code PRN SLOT Units System Description
    CALC.RATIO F062 CLC-00-062 "None" Calculated "Calculated Box Ratio"
    Thanks in advance, Ken . . .
    Jan 2008
    Calc pids go in 7.5 for viewing after you log with BBL. that expression goes in the calc.pids.txt file.
    Apr 2009
    Quote Originally Posted by bballer182 View Post
    Sure enough, the BBL session has the data after selecting the ratio PID. Data doesn't appear to be useful though. Often after shifing into second, the ratio still shows 1.xxx and 3rd still shows 2.xxx.
    Strange it doesn't have a built in way to log gears for a manual.
    Apr 2009
    Anybody know how to get the Oil Temp logged??
    Which vehicle/year/model...?
    For manual transmission, there is no way to know the current gear nor the ratio.
    Apr 2009
    2001 Corvette Z06 , Manual
    Jul 2003
    I am going to make a calculated PID for it...
    it shouldn't be too hard...
    mph/rpm = xx if whatever whatever output 1st 2nd 3rd... that is the logic...
    Sep 2007
    Just trying to make sure I understand...
    Calc.pid's AREN'T Viewable in the V2 while BBL'ing? They are only viewable after the log has been made and saved and loaded into my laptop for later viewing?
    Quote Originally Posted by Jasondt2001 View Post
    That is correct.
  1. Does current BBL software work OK?
    By 02Z06 in forum FlashScan V2 BB Logging
    Last Post: August 15th, 2008, 11:14 AM
  2. V2 current usage?
    By Cougar281 in forum FlashScan V2
    Last Post: February 19th, 2008, 11:05 AM
  3. force motor current
    By 69camaro5speed in forum General
    Last Post: December 8th, 2006, 10:47 AM
  4. CarFax... Anyone have a current Account?
    By MN C5 in forum Lounge
    Last Post: November 13th, 2006, 03:17 PM
