I installed a 3200 stall in my 99 camaro Z28 and now in the 2-3 shift it either bounces off the limiter or its the fuel cutoff, anyone know this problem or how to fix it? heard someone say its called stall wall...idk
Either lower the "shift at rpm" for 2-3 shift a bit, or, raise your rev limiter a bit.
The larger stall will cause the RPM of the motor to flash to the RPM limiter as the trans changes 2-3.
I always change the "shift at rpm" setting (a little bit then try it, if it still happens, lower a little more etc....)
Dave.
