Results 1 to 10 of 18
Thread: Question about NEW PID availability... Engine Oil Temperature?
    Sep 2007
    Default Question about NEW PID availability... Engine Oil Temperature?
    Hi guys and girls of EFILive!
    As if you didn't have ENOUGH crap on your to-do-list
    But I was wondering if it is possible to have that PID available to us?
    The reason I ask is I was reading about the engine oil life and the parameters it monitors and one post said it takes into account engine load and OIL TEMPERATURES... I would LOVE to have that, as I have a 2 gauge pod and the three gauge pod gets in the way of my sunvisor and I don't need another gauge unless I can get it from my computer
    Thanks guys!!! I'm LOOOOVING the new V8 features!!!!!!
    - Jason
    We currently have Oil Temp PID's for the gas E38/E67 ECM's, if the LBZ/LMM ECM does not validate the Oil Temp PID's then it means it doesn't support reporting it via the scantool.
    Sep 2007
    I hadn't seen the oil temp PID for the LBZ/LMM even listed, or I would try to validate it - am I doing something wrong? I'm looking in the blackbox logging selection area.
    Jan 2008
    take the pid name from the E67 or E38 list and manually enter it into your options.txt and try to log it. Chances are that if it is available for the E35 (LBZ/LMM) it would be the same name as the E67/38.
    Apr 2008
    I don't think it will work. Unless it is referenced in the .pmm file it may not know how to interupt the PID.
    Brian
    Lifetime Member DURAtotheMAX's Avatar
    Nov 2005
    none of the duramax ECM's monitor oil temperature...only oil pressure.
    ben
    2005 Silverado, CC/SB, 4x4, LT, LILLY/Allison
    12.9s @ 108 mph
    many thanks to Ross and Paul
    The E38 / E67's don't measure it, it's calculated, so it's possible it might have existed in the LBZ/LMM at least, but if those PID's don't validate then the answer is they don't.
    Feb 2008
    Quote Originally Posted by DURAtotheMAX View Post
    ben
    and low level
    12 Second LMM
    Nov 2005
    Quote Originally Posted by MMLMM View Post
    and low level
    correct Mike
    12.9s @ 108 mph
    Jan 2008
    Quote Originally Posted by Brian1 View Post
    Brian
    Think out side the box. Maybe use the E38 or 67 pmm file to see if the pid validates on the E35. dont try using your normal pid list just try validating the oil temp pid only. Ive done this when tryin to figure out the EGT temp probe off of an LMM for the LBZ. http://forum.efilive.com/showthread.php?t=9987
  1. temperature vs injectors
    By fezz57 in forum Gen III V8 Specific
    Last Post: September 29th, 2010, 10:50 PM
  2. PID availability
    By LinearX in forum General (Petrol, Gas, Ethanol)
    Last Post: February 18th, 2010, 12:47 PM
  3. V8 BBL Logging LBZ Engine Coolant Temperature Problem
    By Jasondt2001 in forum FlashScan V2 BB Logging
    Last Post: May 24th, 2009, 09:22 AM
  4. coolant temperature
    By ws6togo in forum General (Petrol, Gas, Ethanol)
    Last Post: June 9th, 2007, 05:23 PM
