I finally installed the wideband on my truck, havent' yet tuned. I'm noticing the low load sections are a little fat and so is PE, but it's not as bad as I was expecting. At any rate, I'm wondering if when I lean my low load cells to stoich will that net a lesser pump shot? The black box's lack of pump shot/transient fueling tables makes this suck if this is the case. Stock pump shots are usually a bit conservative anyway.
