Results 1 to 3 of 3
Thread: Car Dies with IAT plugged in
    Jun 2009
    Default Car Dies with IAT plugged in
    I just downsized my cam and lowered my compression for a FI setup. I've run into a strange issue. This is a LS1 418 N/A at the moment. The MAF is deleted. Prior to the cam swap it was on spec as far as the tune goes.
    Without getting in to a lot of detail the main problem is it idles like a car that just got a new cam 'with the IAT unplugged' no tuning yet. When I plug the IAT in it barely stays running very rich it seems and any addition of power will almost certainly kill the engine. Without the IAT you can add power.
    What's the problem why is the IAT sensor causing the engine to run worse?
    Apr 2009
    have you adjusted the airflow to suit the new camshaft ? done a sensor check (if possible) or tried another sensor ?
    Oct 2006
    Without the IAT plugged in your airmass calculations will be out.(The reported IAT will be -39degC). This will cause your car to run rich.
    The Tremor at AIR
  1. RR dies
    By minytrker in forum RoadRunner Real-Time PCM Emulator
    Last Post: October 10th, 2007, 10:01 PM
  2. Left WB Sensor plugged in all night
    Last Post: July 14th, 2007, 06:32 PM
  3. Car Dies With A/C On
    By vetteboy2k in forum Custom Operating Systems
    Last Post: July 27th, 2006, 02:31 PM
  4. Car dies when i hit the clutch...Little help plz
    By killaz in forum General (Petrol, Gas, Ethanol)
    Last Post: June 12th, 2006, 11:32 AM
  5. Car just dies
    By 1bar in forum General (Petrol, Gas, Ethanol)
    Last Post: April 8th, 2006, 05:05 PM
