anyone having problems resetting trims with the scanner on the 2010 camaro??
LS1joe,
What problem are you seeing...?
Post screenshots.
Joe.
When i have the scanner open and logging and I go to the fule trim reset and press the button nothing happens, I see on the scanner that the trims don't reset.
We don't have a 2010 here to test on, but we will try it on another E38 vehicle.
Does the scan tool indicate any error when you press the button ?
Just tried on a 2009 E38 and the long term trims get reset to zero by the E38 Fuel Trim Reset DVT control.
