I am trying to run the AutoVE with a AEM UEGO wideband using the serial output. I configured the com port on the V2 to use the AEM, and it is displaying correctly (Both AFR and EQ).
What AFR PIDs should I be logging on the V2? The tutorial suggests the following:
CALC.AFR_XXXn
CALC.BEN_XXXn
I can't find either of those in the "Scan and Tune" utility under "F3: Black Box Logging" for the "LS1 99+ Auto" PIDs, so I selected WO2AFR1 (Serial AFR) and AFR (Commanded AFR) on the V2 for logging instead of CALC.AFR_XXXn, but what should I be using for CALC.BEN_XXXn?
Also, what should I be using for a map inside of the scan tool? I can't find a CALC.BEN.map.
