Results 1 to 10 of 17
Thread: Auto Tune with Custom OS and no MAF???
    Lifetime Member BowlingSS's Avatar
    Nov 2003
    Default Auto Tune with Custom OS and no MAF???
    I went many days tuning using the AutoTune Doc and Mr. Ben. All the tuning using Ben was 4000 and below. Now I have OS 3 installed and have PE disabled. I still monitor BEN but wanted to know how everyone is tuning 4000 and above. Are you using the AFR/RPM table in the custom OS? I have not changed mine yet from first setting it up at 14.63 up to 90kpa and 13.00 at 95-100. What kind of AFR is everyone running from 0-90 and from 95-100?
    For the last month I have been getting more KR than before. It could be because of the gas problems. I am not sure. I always run 93. I guess this is another subject but I was wondering if the two have anything in common.
    Everyone have a good weekend.
    Cheers.
    Bill
    2011 Camaro 2SS/RS L99 RJT
    CAI, Inc. Cold Air Induction;ADM Scoop
    Rx Catch Can;Rx Breather;Roto-Fab Washer Container
    VMax Ported RJT Throttle Body
    XSPower Headers and XSPower 3" Exhaust System
    Elite Engineering Tunnel Brace,
    Gorilla Wheel Lock System;
    Tinted Windows 35%;EFILive Tune
    Nov 2003
    Anyone.
    Bill
    Hi Bill,
    Just a note, you are better off not having your AFR's set to 12.95 below 800 RPM, reason being, is if the engine ever stalls, MAP will go to 90 - 100kPa and the PCM will throw a bunch of fuel in (not so good).
    As for the KR, is it happening at one spot only?, what are the actual AFR's at that point and timing?
    12.95:1 AFR is about as high as I would go, I run my car at 12:3:1AFR, it's not on the edge and allows a bit of safety in hotter weather. Many would dispute that I am losing power by doing this, possibly, but I am not at the strip everyday, so if I am losing 10 - 15Hp by running a touch richer on the street I am not worried.
    I found (on a dyno) the power difference between 25deg timing and 28 was very small, which tells me the motor does not want more than 25 anyway, so that is what I am running.
    So in summary, my street tune I run mid 12 AFR's with about 25 timing.
    As for the bad gas problem.......this might help.
    http://www.flat-d.com/
    BTW, your post only showed up on my PC this morning :?
    Lifetime Member MN C5's Avatar
    Mar 2005
    Looks like you need to have a professional fit you for that :lol: :lol:
    Ha ha... emissions control... :lol: :lol: :lol:
    Jul 2005
    Above 4k I use a loading dyno.
    Normally aspirated I run my AFR at 13.2 makes best power there and its rich enough to be safe. Of course you have to be make sure that commanded and actual are spot on.
    Forced induction I run at 11.6 and change the iat enrichment table to add fuel above 65 degC.
    U should find that the knock normally occurs at the same places. Especially below 2k.
    I use a KR map to subtract timing at those points. I advance the whole high octane table taking away some timing at the trouble spots.I also made a spark scaler map so I can monitor how much of the high octane table it's using.
    \"You Can Never Have Enough Horsepower\"
    Nov 2003
    Quote Originally Posted by caver
    Do you run the the AFR Table at 13.2 just at 90 -100 kpa? What do you have your table set to in the other cells? I am running 14.63 everywhere except at 90-100kpa. I just want to make sure I have setup this table right.
    My timing has been reduced a number of times to help with the KR. I was not getting this KR a month ago. Most of it started after going to the Custom OS. I am not getting that much. I also changed gas stations a few weeks ago because my regular station keeps running out of the good stuff. I think the gas is not as good.
    Bill
    Nov 2003
    Hi Bill,
    I like the bad gas link. :lol:
    Do you run the whole table at 12.3 or just the higher end of it?
    I am also running in the low to mid 20's for timing.
    Thanks.
    Bill
    Jul 2005
    I run 14.63 up to 70kpa untill 4k then I only run it up to about 55kpa.
    I blend it from 14.63 at 70kpa to 13.2 at 85kpa. Thats WOT for me at 5000ft.
    Seems to work nice. Run it at 13.9 to 14.2 under 1600 rpm cause of the cam
    Car has Fast manifold 94mm Starr TB bigger valves BIG cam short headers and dual 3" exhaust.
    Makes 370hp wheels, corrected on my dyno dyno calc's it to 500hp engine.
    Bill,
    Ben from EFI-101 gave me some interesting advice on AFR's one day, I don't want to steal he's thunder, but running leaner AFR's down low can have negative results, mind you, it can also make power on some engines, so whatever you find works for you is probably best.
    I do run 12.48:1 commanded for the most part, however, because of table interpolation it's not like P.E with a fixed value, look at my table from 95 - 100kPa and that pretty much commands 12.48 at 98 - 100kPa where the engine runs at WOT. upto 90kPa it is 14.63 everywhere.
    I have run 28 - 29 degrees of timing on a dyno but it made no more power than 25, so I left it a 25. Though, with some cold nights here lately we bumped that back up to 28
    Also, because of fuel prices I have stopped using Premium (98 Oct) and have dropped back to 95 Octane.
    BTW, I just noticed looking at a log I did tonight my BEN factor average from 4800 - 5500 is 1.0057
    You might also be interested in this link -
    http://www.efi101.com/forum/viewtopic.php?t=808
  1. Auto Tune
    By GMPX in forum Please Read First
    Last Post: November 29th, 2023, 02:17 AM
  2. Holden VE SS Auto tune
    By ntae in forum E37, E38 & E67 PFI ECM's
    Last Post: March 28th, 2008, 01:09 AM
  3. 98 ls1 auto f13 tune help!!!
    By ls698ta in forum Gen III V8 Specific
    Last Post: March 15th, 2008, 03:37 AM
  4. A/F tweak vs auto tune
    Last Post: February 19th, 2006, 10:06 AM
  5. VY SS Auto tune ??
    By bink in forum General (Petrol, Gas, Ethanol)
    Last Post: July 25th, 2005, 04:58 AM
