Results 1 to 2 of 2
Thread: two general tuning questions - B1901 and other?
    Lifetime Member Bruce Melton's Avatar
    Oct 2003
    Default two general tuning questions - B1901 and other?
    First.
    My previous professional tuner changed my B1901 max allowed engine torque from 650 to 866. Is this of any valve with a ~425 hp LS1 MN6?
    Two,
    In that an 02-03 Z06 have different op system than an 04 is there any reason why an 04 would generally have less perceived torque or grunt than the previous two years? Is this 04 like others or an anomay?
    Questions one and two are not related to the same cars.
    I appreciate you thoughts. Thanks
    Bruce
    PowrMax Performance
    100 mm PowrMAF
    EFILive Distributor dfe1's Avatar
    Jan 2005
    You may be confusing newton/meters with foot/pounds. In the tables I've seen, the max setting is 640 lbs/ft. Typically, this number is set between 600 and 640, just to dial it out of the equation. Don't know about the 04 versus 02/03 values. Could be that the 02/03 setting was deemed to be the cause of too many warranty claims.
  1. > > > General Tuning Information < < <
    By TAQuickness in forum General (Petrol, Gas, Ethanol)
    Last Post: January 22nd, 2015, 03:26 PM
  2. B1901 Max Allowed Engine Torque
    By SHOGOR in forum General (Petrol, Gas, Ethanol)
    Last Post: May 31st, 2009, 04:29 PM
  3. Some general n00b questions, your input is appreciated
    By Supercharged111 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 28th, 2009, 06:57 AM
  4. B1901
    By tblu92 in forum Gen III V8 Specific
    Last Post: February 17th, 2008, 09:52 AM
