Results 1 to 5 of 5
Thread: LB7 to LBZ CP3 swap tune adjust
    Jan 2008
    Default LB7 to LBZ CP3 swap tune adjust
    We changed out the CP3 off the LB7 and put on a LBZ pump today and need to adjust the tune for it. Any help would be great.
    06 3/4 ton PPE,EFI Live,Tranny,Lift pumps
    01 1/2 ton
    Dec 2008
    you have to change table b1010. voltage is different form lbz's to lb7's
    Set up a pid file showing regulator current des and actual
    Adjust b1010 accordingly to get them to match
    2017 Trailblazer 2.5L Dmax
    07 LBZ rc lb EFI - Sold
    05 lly cc lb, EFI 80hp tune-Sold
    01 lb7 rc lb EFI & Road Runner,1000+hp -Sold
    Duramax power
    Apr 2010
    Any updated info on this?
    Lifetime Member dansdieselp's Avatar
    Apr 2009
    Easy way to make the adjustment is to add 10% to the rail regulator current table B1010. Then log your actual vs desired rail pressure and adjust if needed.
    Dan's Diesel Performance
    www.dansdieselperformance.com
  1. trying to adjust speedo ??
    By timvan in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 31st, 2009, 06:58 AM
  2. how to adjust for 160* tstat
    By whackem04 in forum Gen III V8 Specific
    Last Post: September 29th, 2009, 07:16 AM
  3. what to adjust for speedo???
    By newguy2diesel in forum Gen III V8 Specific
    Last Post: April 2nd, 2008, 04:24 PM
  4. What needs to be done to swap to SD tune?
    By zapp168 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 31st, 2007, 04:57 PM
  5. Mapping c6101 in scantool to adjust in tune
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: February 2nd, 2006, 06:30 AM
