i loaded all new firmware and now when i scan using V2, all the pid are in metric and i cant change to imperial, tried pressing enter, doesn't work, and also how do you change the pid selections to imperial when making a custom file in F3 BBL
FYI
After alog is loaded with the scan.exe
you can toggle between units in the PIDS tab.
It does not make a difference in the maps you have loaded either.
Selecting metric or imperial for logged PIDs will show those units on the data tab.
Your map that is linked to a PID in metric will show data
even tho you have selected imperial units on the PIDS tab.
LC-1 WBO2
Can someone look at my Options.txt file tell me if you can see why I can't select imperial units?
Thanks in advance, Vinny
VHR,
Are you running new firmware or old firmware...?
Bootblock 2.06.02
Firmware 2.06.12
Thanks for the quick reply!
Vinny
how come this new firmware is so difficult, it was much easier before, isn't it suppose to better???
try loading this one
I loaded your options file, but I still can't change units.
did you load the file w/ the -1 or you edited the name of file, after that make sure you have all up to date firmware and also did you install 8.1 correctly by deleting the old files and stuff because i did it w/o deleting files and thats what happened to me, you should be able to press enter and change to imperial.
