Results 1 to 8 of 8
Thread: Someone have a Custom Options File?
    Aug 2008
    Default Someone have a Custom Options File?
    anyone have an options file for the newest firmware, in imperial units that i can load onto FS.
    Which version of FS firmware do you have...?
    Aug 2008
    the newest one, the one from june 9 2.06.12 and the correct boot block
    Apr 2008
    Just what is in the options.txt file as default is what you want as Imperial?
    Or are you logging other PIDs?
    With the ScanAndTune app from V8 you can read the options.txt file from the Flashscan II and then go and change the PIDs for each PID for that PID set to Imperial. Then program them back to the Flashscan II.
    Brian
    Quote Originally Posted by turboolds View Post
    Ok, here is my Options.txt (see attached)...
    copy it to the right place which should be:
    C:\Documents and Settings\All Users\Application Data\EFILive\V8\Config
    Use the pidlist named "LS1B" "eng/tran".
    What car do you have...?
    Quote Originally Posted by Brian1 View Post
    Brian
    +1
    Exactly what Brian said.
    Have you seen this before:
    Aug 2008
    i have an o1 zo6, i like the way the old version had all the different pcm, and you could switch to imperial easier
    In the blue section (upper left) you can select the controller and name the pidlist (rightclick->Properties).
    In the green section (lower left) you can set a pid's custom units (rightclick->Properties) as shown above (for VSS the "Quick Select" dropdown shows mph, the numerical constants appeared when mph was selected).
    You do need V8.1 installed to be able to do that.
  1. options.txt file
    By chevydieselsmoker in forum FlashScan V2 BB Logging
    Last Post: January 9th, 2009, 01:57 PM
  2. Custom/DIY calibration definition file?
    By jimter in forum General (Diesel)
    Last Post: October 10th, 2007, 08:25 AM
  3. Red X On My Options..help??
    By killaz in forum General (Petrol, Gas, Ethanol)
    Last Post: June 10th, 2006, 04:32 PM
  4. Swapping motor and trans, question about file & custom O/S
    By thunder550 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 15th, 2006, 08:14 AM
