V7.3 010 has been made publicly available here:
http://www.efilive.com/downloads/downloads_730.html
Important note for 1998 PCMs
Earlier versions of EFILive included two *.txt files:
You must delete those two files or EFILive will decode the 1998 PCMs incorrectly. Most likely you will see many "Out of Range" calibrations until you remove those two files.Code:\Program Files\EFILive\V7\Calibrations\19980100.txt \Program Files\EFILive\V7\Calibrations\19980200.txt
