It looks like is using the options.txt from a older version of the software, or it was added manually.
2003 Chevy S10 4.3L LU3 LS1B Auto
48 LB injectors
Race Proven Motors 2114 intake
T70 turbo.
I am Beta testing though...oops...
I'll try & remember...L31 is the controller name. If it doesn't come up you have to go to options.txt file and manually add it like nevinsb said...it's pretty simple
FLASHSCAN V2 & AUTOCAL
I added it to options.txt however it is still not in my list of controlers.
This is GAMEOVER's screen shot the part that is circled in red I don't have.
The part in red on that screen shot is written by you in the Scan&Tune under controllers-caption #1 & #2
post up your options.txt file so we can look at it
On the controller pulldown you have to scroll down (the Vortec 98-00 is 6th from the bottom after you scrolled to the end).
You downloaded/installed V8.1 build 58, right...?
I have v8.1.2 build 58
The V8/Pid Descriptions/L31_PIDs.txt is also missing.
I was able to manually add it to the options.txt (But I don't have anything to test it on). L31Sleeper, did you add it both to the beginning of the options.txt file and to the end of the file (where it says PSL_23 or the next available slot)?
48 LB injectors
T70 turbo.
