Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Black Box Logging
  1. #21
    Nov 2007
    I DID IT, I DID IT !!!
    I still don't know if it is going to work but I will try tomrrow.
    So here is what you have to do. Options.TXT only edits the
    main selection menu. The controller menu is in EFILive.INI
    C:/Program Data/EFILive/V8
  2. #22
    Nov 2007
    OK guys I did it. All I had to do is UPLOAD the info from my V2
    to the software, doing that gave me the same menu that GAMEOVER has.
  3. #23
    Aug 2008
    Glad you got it to work...
    FLASHSCAN V2 & AUTOCAL
  4. #24
    Apr 2008
    Yes seems there is a bug somewhere that sometimes does not create the EFILive.ini during certain procedure that I never figured out. I never had the issue on the EFILive but dealt with one guy that could not select the controller in the pull down menu. Turned out he was missing the controller section in the EFILive.ini file. He did uninstall and reinstall but never got it back. Final cut and pasted the contents from mine and it worked. Now apperantly working with Pual on this he thinks the file is locked during updates. But I can unistall my build 58 and it deletes the EFILive.ini file. Pual was thinking of creating too files where some things that do change go in there and others stuff that does not change goes in another ini file.
    Brian
  1. Black Box logging?
    By -=Mod=- in forum Gen III V8 Specific
    Last Post: August 18th, 2009, 04:45 PM
  2. V2 black box logging?
    By articSS in forum FlashScan V2
    Last Post: September 23rd, 2007, 04:57 AM
  3. is black box logging available on v2 yet ?
    By imtduncan in forum General (Petrol, Gas, Ethanol)
    Last Post: August 18th, 2007, 12:11 PM
  4. V2 Black Box Logging
    By ARK 99coupe in forum General (Petrol, Gas, Ethanol)
    Last Post: March 4th, 2007, 07:28 PM
  5. Black Box Logging
    By C3vette75 in forum General
    Last Post: June 19th, 2005, 01:07 AM
