Results 1 to 7 of 7
Thread: powering a laptop while scanning?
    Mar 2009
    Question powering a laptop while scanning?
    In the box that my EFILIVE V2 came in was a card saying NOT to power your laptop from an inverter while the V2 is connected, doing so will damage the 2 units. What about powering the laptop from the A/C adapter plugged into my garage? Or should I only use batery power from the laptop to powe it? The reason I ask is that the laptop I'm using slows WAY down when on battery power, and the screen on it dims to save battery to the point that I can't hardly see it during the day.
    Nov 2006
    This is a controversial topic.
    I personally have used a POWERLINE 0900-73 200 without issue.
    EFILive condemns the use of DC to AC inverters while using Flashscan.
    LC-1 WBO2
    Mar 2005
    I have also used an inverter to keep the battery charged while scanning on long trips with no problems. What can happen when using them that creates the problem?
    2014 Silverado 4X4 6.2L
    2010 Camaro 2SS-RS L99
    2007 Sierra Denali 6.2L
    2005 1500HD 4X4 Quadrasteer 6.0L, COS3 SD
    Nov 2006
    Nothing if you have a good inverter, make sure it has surge protection.
    They are made for powering electronics, not frying them.
    But like I said EFILive condemns the use of them.
    You will need to decide whether or not it's worth the "risk".
    Many people have not had a problem and the only incident I have heard
    about was from Blacky.
    I don't recall the circumstances but because of this
    inverter use will void your warranty.
    LC-1 WBO2
    Mar 2009
    But what if I am in my shop where land line power is available? Will that void my warranty to powe the laptop through a wall plug in my shop while I'm connected to the V2 and vehicle?
    Mar 2009
    what about a dc to dc converter based cigare lighter charger? do they void warrenty because i have seen them around.
    May 2008
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
  1. V2 not powering up
    By aaronr in forum FlashScan V2
    Last Post: October 25th, 2009, 05:15 PM
  2. Need Laptop
    By jorge in forum General (Petrol, Gas, Ethanol)
    Last Post: June 18th, 2008, 05:54 AM
  3. Laptop
    By Chevy366 in forum Lounge
    Last Post: February 16th, 2008, 04:10 AM
  4. Scanning 06+ TCM's
    By Cougar281 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 30th, 2007, 09:43 AM
