Results 1 to 10 of 15
Thread: Licensing question...license key said "scanner only" w/ v2 scan & tune
    Jul 2006
    Default Licensing question...license key said "scanner only" w/ v2 scan & tune
    Hello,
    My V2 just showed up today. The license sheet attached to it with the serial number says "scanner only". On the Help->Registration screen, I filled in the parameters exactly as listed on the sheet, including leaving "scanner only" selected.
    I've only scanned a vehicle so far, but noticed in the "console output" of the scanning session that it really seems to think I purchased scan only, rather than scan and tune. Just wanted to make sure I'll be able to flash the PCM, and if not, what I need to do to correct the situation.
    Should I just re-enter the registration info with "commercial scan & tune selected"?
    Thanks much
    --Tod
    Apr 2008
    The Registration card does not say Commercial Scan and Tune?
    What was the cost you paid for the Flashscan II?
    If it does not say scan and tune then that key will not work for scan and tune.
    Brian
    I notified Tech Support.
    Jul 2006
    Thanks all...
    I paid $750 (vendor having a sale), no WBO2, it's a scan and tune.
    Apr 2008
    Yes for that price it should be tune and scan. Paul, Cindy, or Ross may have to get hold of you and the person from the company you purchased it through to get it all sorted out. I would say the serial number should help identified the way the package was to be sent out. Hopefully the reseller to you did not make the mistake and sent the wrong box out to you. Never know if a stock boy just grabbed the closest item on the shelf. Just some random thoughts but again these people above will help you get it all straighted out and quickly as possible. Just give them some time. They are from on the other side of the planet.
    Brian
    Jul 2006
    Are the physical units the same, i.e., is it just a license upgrade issue, or would I have to send the unit back?
    Under FlashScan V2 VIN Licensing, I'm getting "the attached device is a scan only device and cannot be used for reflashing, so no licenses are displayed here."
    The "San and Tune" and "Scan Only" devices are identical. A "Scan Only" can be easily updated to a "Scan and Tune" by entering an activation code supplied by EFILive or one of its resellers via email.
    Please contact the reseller who sold you the FlashScan, explain that it is not the correct type of product. The reseller can then obtain the correct activation code form EFILive to update your FlashScan device.
    Sometimes a reseller will ship a "Scan Only" device in place of a "Scan and Tune" device if they are out of stock. In that case the activation code is normally sent with the shipment. Just check the package contents (including the shipping packaging) to make sure there is no other document that contains the activation code.
    Jul 2006
    Thanks, have sent an email to him. He's been a great help so far so I don't think it'll be a problem.
    And greatly appreciate all the prompt responses!
    --Tod
    Apr 2008
    No should be a simple license number change. The units are the same. If they can confirm what you should have I would think they send you some new numbers to get it fulling running.
    Brian
    EFILive Reseller kbracing96's Avatar
    Sep 2005
    Tod, It was a miss communication on mine and my distributors part, but I sent you a PM on PT.net with the info you need to upgrade your cable to a scan and tune.
  1. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 02:48 AM
  2. 12200411 retrofit, have efilive "VIN" question
    By rb1 in forum Gen III V8 Specific
    Last Post: June 2nd, 2007, 07:39 AM
  3. Scan runs "slow"
    By DaddySS in forum General
    Last Post: December 7th, 2006, 03:52 PM
  4. "PCM is in an Unkown State" & "Reflash Failed"
    By foxySS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 8th, 2006, 12:53 PM
  5. "Service Brake System" message after tune change
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: September 11th, 2005, 02:26 AM
