Results 1 to 8 of 8
Thread: Case Relearn
    Dec 2008
    Default Case Relearn
    I have a V2. I downloaded the new version of EFILive and iam having trouble with the case relearn. I Folowed the proper procedures. I bought the car above 4 grand and no shutters or no cutoff. The car kept climbing up till 6 grand and i let off. I didnt want to redline it. Is there any problems with this new version or could it be something else? Thanks.
    What car year/model...?
    Was engine warmed up to operating temp...?
    Did you see this screen (attached)...?
    Did you press the CASE button...?
    Was TP and VSS at zero (as shown in pic)...?
    Was parking brake applied...?
    Dec 2008
    hey joe. heres the man to talk too. its a 2001 camaro z28. i followed all the procedures . engine was warmed up. parking brake applied. connected the scan tool. went to dvt, learning, activated then pushed case and the ok showed up. then pressed the gas. I gradually bought rpm's up to 4 grand. i didnt floor it. nothing cut off or i didnt feel anything. so i kept brining them up to 6 grand and let off
    Dec 2008
    and the percents for both tps and vss were at zero
    Did you bring the rpm to above 4000 in less than 10 seconds...?
    The PCM gives you a 10 second limit.
    Dec 2008
    oh theres a 10 second limit. is that as soon as you push the case button?
    Yes, when you press the button you have 10 seconds to get RPMs above 4000.
    Dec 2008
    Thanks for help again joe. Iam gonna try out it again this afternoon
  1. E38 Case Relearn on Locked ECM
    By Raceute in forum E37, E38 & E67 PFI ECM's
    Last Post: November 2nd, 2009, 05:56 PM
  2. case relearn
    By 67LS3 in forum Gen IV V8 Specific
    Last Post: October 23rd, 2008, 02:52 PM
  3. CASE relearn for PCM with new LS2?
    By ArKay99 in forum Gen IV V8 Specific
    Last Post: January 28th, 2008, 06:08 PM
  4. CASE Relearn for the LL8
    By ScarabEpic22 in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: March 6th, 2007, 02:45 PM
  5. CASE Relearn
    By Fratsit in forum General
    Last Post: February 7th, 2007, 10:39 AM
