Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Anyone Tuned An FI Setup To 12.5 AFR WOT?
  1. #21
    Jun 2009
    ideas?
    99 a4 corvette
    3800vig tc ,rpm level 5, 317 heads,a&a blower cam,a&a s trim 10psi,3.42,tsp headers,hi flow cats,borla cat back,550rwhp no meth yet
  2. #22
    Aug 2008
    just some information on plugs might interest someone
  3. #23
    Jul 2003
    where is your wideband located?
  4. #24
    Jun 2009
    if its me ...mine is on the drivers side about a foot behind the collector before the hiflow cat
    99 a4 corvette
  5. #25
    Jul 2004
    hree back to back WOT runs were made and gently driven 1/4 mile to the garage to remove them.
    If you really want to get an idea of the WOT run, you need to put in new plugs, run it hard cut the ignition and grab neutral at the same time, then coast to a stop and pull a plug. All you can tell from that is it's not so lean it's melting the plug. Driving 1/4 mile slowly probably makes the reading close to useless.
    At least that's what I learned back when people actually read plugs to tune.
    Ira
  6. #26
    Mar 2009
    You also need to look at the base of the ceramic, not just the tip of the plug. I know that the base is where the main jet reading of a plug is looked at.
    98 silverado 4wd excb 5.7l, zz4 cam,roller rockers, shorty headers, 0411 swap, Flash Scan V1 commercial
  7. #27
    Mar 2009
    You're also looking for white specks, i.e. detonation. I realize this is supposedly irrelevant to the OP, but it's something to look for nonetheless.
  1. has anyone tuned without maf and o2 sensors???
    By 02sierra4x4 in forum Gen III V8 Specific
    Last Post: September 21st, 2009, 04:35 AM
  2. tuned log scan
    By 2004gmc in forum FlashScan V2 BB Logging
    Last Post: May 31st, 2009, 10:09 AM
  3. TT ZO6 tuned with EFI Live!
    By Redline Motorsports in forum Lounge
    Last Post: August 16th, 2008, 01:37 PM
  4. ve tuned now kr
    By mr.prick in forum General (Petrol, Gas, Ethanol)
    Last Post: April 28th, 2007, 07:59 AM
  5. Can this be tuned out?
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 23rd, 2007, 08:48 AM
