I just ran some logging in my new truck and when I try to read it I get an error $0190: SD Card removed. Is that expected behavior? I have all updates / firmware installed and do not have an SD Card inserted...
2001 Camaro SS
EFILive Custom OS3
Under V2's setup options, set file system to internal.
What is the largest SD card you can run.
DOH! forgot about that option on V2... thanks!
2001 Camaro SS
EFILive Custom OS3
2GB SD Card.
2003 Chevy S10 4.3L LU3 LS1B Auto
48 LB injectors
Race Proven Motors 2114 intake
T70 turbo.
Can that be changed in the firmware?
Are you referring to the 2gb limit? Is so then I believe it is going to limited based on the chipset used for sdcard reader portion.
Brian
Usually, the SD card read/write operations are controlled by individual I/Os on the board, so a firmware update should be able to fix it. I am running a SDHC in my Linksys WRT54G router right now
48 LB injectors
T70 turbo.
Thought it was limited based on hardware. Wonder if there is licensing fee involved on sdhc that would have to be paid much like sonys memory stick setup.
Brian
I thought that the purpose of manufacturers were going to the SDHC was because Microsoft's patent on the FAT file system, they sued TomTom over it, but it looks like devices are still using some variety of FAT for the SDHC.
In any case, my router needed a driver update to go from SD to SDHC, and my GoPro camera needed a firmware update to be able to handle the SDHC. I haven't taken my V2 apart (yet), but I have a hunch it uses software controlled GPIOs, and a firmware update would allow the use of SDHC cards. I am guessing it doesn't run Linux on the V2, so I wouldn't have a clue what I am doing with it. This would be a question for the firmware developers.
48 LB injectors
T70 turbo.
