Results 1 to 10 of 15
Thread: TPS sensor problem
    Nov 2006
    Default TPS sensor problem
    TPS voltage and TPS% will not match.
    After a TPS reset
    0% = .6v
    100% =4.5
    With the engine OFF voltage and TPS% are fine,
    after I start the car TPS voltage goes down and TPS% goes up and swings.
    This is causing idle problems to say the least.
    The TPS sensor wires to the PCM have 0 resistance.
    LC-1 WBO2
    Post a log.
    Nov 2006
    Before I started the car 0.6v = 0%
    After the car is turned off TPS% = 4.7% @ 0.6v LOL
    TPS.efi
    I'm thinking either the TPS sensor is bad or the ignition wires are
    causing interference with the sensor, the problem starts after the car starts.
    LC-1 WBO2
    Nov 2006
    I removed the TPS sensor and found the center "cup" that the TB shaft connects
    into is quite loose inside the housing.
    TPS volts would read 0 if this cup was not centered.
    I could turn the cup to WOT by hand and TPS% would = 0% unless I centered the cup.
    Can someone confirm whether or not it should fit tighter in the housing.
    LC-1 WBO2
    Jul 2007
    Any luck? After my first flash (yesterday) I too am experiencing something similar. Hmmm... http://forum.efilive.com/showthread.php?t=11411
    Nov 2006
    I still see 0.4% TPS after replacing the sensor,
    it is probably due to RFI.
    LC-1 WBO2
    Jul 2007
    Quote Originally Posted by mr.prick View Post
    Oh, is it a constant 0.4% at an idle or just in the key on - engine off condition? 0.4% or 0.4V? Thanks for your help!
    Nov 2006
    0.4% TPS.
    It is not constant,
    if I tap the throttle it will read 0% but it will not always go down to 0%.
    The TPS sensor appears to be very sensitive and RFI is probably the problem.
    A ferrite bead around the TS wires may help.
    LC-1 WBO2
    Jul 2007
    Interesting, thanks. Let me know how it goes!
    Jul 2003
    Where you able to find out about this?
  1. Problem with DTC PO342 Camshaft Position sensor circuit low
    By LSXstart in forum Gen III V8 Specific
    Last Post: December 3rd, 2010, 03:35 PM
  2. TP sensor
    By Slowrc in forum Gen III V8 Specific
    Last Post: January 29th, 2009, 06:24 AM
  3. PID Problem w/BBB - Asked by Cougar 281 (FRPDES problem)
    By Jasondt2001 in forum FlashScan V2 BB Logging
    Last Post: March 23rd, 2008, 02:02 PM
  4. IAT sensor
    By Chevy366 in forum Lounge
    Last Post: August 3rd, 2007, 11:49 AM
  5. O2 Sensor
    By ASSAMI in forum General (Petrol, Gas, Ethanol)
    Last Post: October 8th, 2006, 02:04 AM
