Ross,
I'm trying to link a BBL to the tune tool for table F0101 Fuel sensor primary.
The logging PID. Fuel Level Sender/Sensor Voltage Primary,: GM.FLS. The LBZ tune file has values for that table in mv not volts, as the PID is logging in volts.
When adding F0101 to the cali_link txt file for the LBZ. It won't link because of that.
When I added F0101 for the LB7 to the cali_link txt file. The data linked from the LBZ log to a LB7 tune file and the tune values are in Volts.
Is there another PID or fix for the LBZ/LMM F0101 to calibrate the fuel tank sending units?
