Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Speedometer signal
  1. #11
    Lifetime Member Aloicious's Avatar
    Nov 2007
    Quote Originally Posted by Hocky View Post
    I am currently building a Volvo 242 with a procharged LS1 engine in it.
    The transmission is a T56. The complete engine package comes from a Camaro SS 1999. Some pics can be found at http://www.hocky.se.
    Got one problem with the speedometer. I have retrofitted one electric VDO speedometer from a newer Volvo car and is trying to get this to work.
    Problem is that it wont move...not at all :(
    Anyone done any similar?
    What type of signal is generated from the ECU?
    Is this the same type of signal that comes from the transmission?
    Thanx!
    I don't know what the VDO gauge requires as far as signal strength like you've been talking about. but the VSS signal reluctor wheel inside the T56 trans is a 17 tooth reluctor, many other trans' use a 40 tooth reluctor. when I swapped from a 4L60e to the T56 I ran it once before recalibrating the speedometer info and with the 40 tooth settings in there the speedometer would barely move, you might want to make sure your settings are correct for the 17 tooth reluctor.
  2. #12
    Jul 2004
    As I recall the output on the 1999 only pulls down so to get a signal out of it you'll have to add a pull up resistor to 5 or 12V. This is one of those times when having access to an oscilloscope comes in real handy. The next year they had an internal pull-up.
    Ira
  3. #13
    Nov 2008
    I did try with a 1k pullup with no result :(
    I think the VDO speedometer is triggered by a hall sensor in the rear axle as standard om the Volvo where the speedometer is from.
    ecu - signal converter - speedo
    or
    T56 sensor - pulse converter - speedo
  1. ECM to ABS speed signal
    By THEFERMANATOR in forum Duramax LB7
    Last Post: June 28th, 2009, 04:23 PM
  2. A/C request signal
    By burtoncr in forum Gen IV V8 Specific
    Last Post: June 3rd, 2008, 07:37 AM
  3. MAF Signal
    By Spindoctor in forum E37, E38 & E67 PFI ECM's
    Last Post: March 2nd, 2008, 02:23 PM
  4. Same OS different Speedometer Seg ID's
    By heavyfoot in forum General (Petrol, Gas, Ethanol)
    Last Post: April 28th, 2006, 02:02 PM
  5. How do I get the IAT signal to the PCM
    By mtnman in forum General
    Last Post: October 9th, 2005, 08:11 AM
