Results 1 to 7 of 7
Thread: Unlicensed PCM
    May 2006
    Default Unlicensed PCM
    I was out doing a little tuning, I got one reflash and now I am being told that my PCM is unlicensed.
    Any help would be greatly appreciated.
    I just tried to send a request for support via the EFI Live customer support page and when I entered the Authorization code I am being told it is invalid.
    I tried to upload the .blx file but it is an "invalid file".
    Not sure what to do from here.
    Is this the same thing? http://forum.efilive.com/showthread.php?t=4093
    My vin # has been zeroed.
    2002 ws6 stock short block
    GMPP cnc LS6 Heads 11.4:1 cr
    .576 i .581 e 116 lobe
    D1SC @ 10#
    723 rwhp 654 rwtq on E-85
    I have sent you an email with the appropriate info to fix the problem.
    Let me know if you have not received it.
    May 2006
    I just got it, thank you very much.
    D1SC @ 10#
    Junior Member OLS108's Avatar
    Nov 2007
    I had this happen with an E38 as well, whats the fix ?
    Send the following info to me (paul@efilive.com):
    1. The *.blx file that is created when you get the "PCM is unlicensed" message. See this web page for info on how to identify the correct file: http://www.efilive.com/index.php?opt...111&Itemid=121
    2. A screen shot of the Tune Tool window: Help->FlashScan V2 VIN Licensing. To obtain a screen shot: Press Ctrl+PrtScr to capture the screen, open Start->All Programs->Accessories->Paint. Select Edit->Paste. Select File-Save As and save the file as *.PNG file type.
    3. Your V2 serial and auth code as per this web page: http://www.efilive.com/index.php?opt...110&Itemid=120
    Nov 2007
    The Orginal computer ( hard drive ) is no longer in service, is their any other way ?
    Quote Originally Posted by OLS108 View Post
    Generate a new blx file of a read on the affected ECM.
    Items 2 and 3 can be obtained regardless of what machine you are using now.
  1. Licensed PCM now unlicensed?
    By PSWired in forum General (Petrol, Gas, Ethanol)
    Last Post: October 8th, 2005, 08:43 PM
