Results 1 to 10 of 19
Thread: How to tune VE tables on a '98 ???
    Sep 2005
    Default How to tune VE tables on a '98 ???
    I read somewhere that you supossed to use the secondary, or I think ELILive calls it "backup VE" table to tune VE on the '98 model LS1's ??
    This true??
    Also, any tutorials on how to adjust the VE using Fuel Trim's ?
    I figure you could log LTFT , and map LTFT % (gm's/cyl) vs. RPM, that would tell you where to adjust the VE table, but can you just then copy/paste those values to the VE table to correct and bring the LTFT / stft closer to zero?
    I don't have a WB yet, and it will be a while, mean time I want to get a halfway decent tune on the car as far as fueling (except for WOT, of course)
    Please help a noob get started here !
    Aug 2004
    Main ve is used when you are using the maf sensor.
    The backup ve table gets defaulted to when there is a maf failure.
    To tune, i just make the changes to both, copy and paste with " lables" from the main to the secondary makes it very fast to do.
    Also make sure to note that there are other tables that swap when not using a maf sensor. Timing tables, spark adaptive learning, And another big thing to correct is the max line pressure on maf failure.
    Lifetime Member 87gmc's Avatar
    Apr 2004
    Also can autotune be used on 98's?
    Sep 2003
    Yes it can you have to setup a map for the primary and secondary ve tables
    Larry - HumpinSS
    Jan 2004
    Quote Originally Posted by Dirk Diggler
    Shouldn't have to set up two maps, should only need one. If you make a primary map and "Copy with Labels" like Jesse mentioned, it should take the values for the secondary and plot them in with no problems.
    Sep 2003
    Quote Originally Posted by black02ss
    What about the 3% discrepancy we saw from logging the primary adn secondary tables separate
    Larry - HumpinSS
    Jan 2004
    :? That is a very good point..... hmmmmm
    Sep 2005
    Quote Originally Posted by wait4me
    So if the backup table gets used when MAF failure detected, how do you tune VE in SD/open loop mode? You can't copy the backup VE tables to the Primary tables, because the backup has less columns.
    Man, the more i try to learn the more confused I become.
    Why not just tune the VE with the MAF connected. That would compensate for both VE error and MAF errors together, right?
    please help me understand, I want to get my LTFT's straightned out.
    Sep 2004
    Get a wideband. I put it off for too long. Once I got it, and did the auto VE, I was happy right off the bat. Much easier, and much less time consuming. I have not gone back to the MAF yet, but I plan on creating the Main VE table in Excel from the secondary VE, then copy-paste. I figure I would avg the columns to create the additional 1/2 MAP range. IE: avg the 20MAP wiith the 30 MAP to get my 25MAP, and so on. Than I assume there may be some fine tuning after that.
    Hope this helps,
    'J
    Senior Member dissonance's Avatar
    Sep 2003
    I was planning on trying to tune my ve tables this weekend but the tables do not match as stated above.
    So what steps would need to be taken with a wbo2? And once we get it nailed down we could update the added info to the autove tuning guide.
    wait4me talked about timing, spark adaptive learning and line pressure on maf fail. I have been looking around in the cal and was unable to find these maf fail values or are you talking about turning off dtc’s?
  1. Replies: 16
    Last Post: June 1st, 2010, 08:05 PM
  2. LS6 Pro Charger Tune Timing Tables Needed
    By bad boyz racing in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 8th, 2009, 10:35 PM
  3. Tune VE and MAF tables or leave VE stock and tune MAF only
    By BlackGMC in forum Gen III V8 Specific
    Last Post: August 4th, 2008, 08:05 PM
  4. spark tables SD tune
    By ZL1Killa in forum General (Petrol, Gas, Ethanol)
    Last Post: January 3rd, 2006, 03:19 AM
  5. MAFless tune: How do I enable both the Hi-Lo Spark tables?
    By SSbaby in forum General (Petrol, Gas, Ethanol)
    Last Post: February 23rd, 2005, 02:50 AM
