Results 1 to 5 of 5
Thread: Any reason not to run OLSD fulltime in noncos?
    Default Any reason not to run OLSD fulltime in noncos?
    If I set the high/low octance tables the same. Leave KR enabled for safety. Turn off strims, ltrims and O2's. Then tune for sd as normal, then enable the maf? For a 2000 Vette.
    Later will add COS5.
    Lifetime Member Biggsy's Avatar
    Jan 2007
    You can run OLSD on a std OS (HSV did it on a GTS), it will run off the Low octane timing table.
    Dave.
    Sounds good to me. Monitor the wideband AFR periodically.
    Feb 2008
    I've run OLSD for around 4 years in my Vette. Hell I even got 18mpg pulling my drag racing gear trailer last year on Hot Rod's Drag Week with very minor adjustments needed now and then. Once the VE and timing tables are set let it go.
    Thanks. Willtry that short term.
  1. any reason to upgrade OS?
    By whackem04 in forum Gen III V8 Specific
    Last Post: September 28th, 2009, 01:10 PM
  2. Switch from OLSD to OLMAF
    By Alex99 in forum Custom Operating Systems
    Last Post: February 9th, 2009, 03:54 AM
  3. p1514 and no reason
    By tazinhawaii in forum Gen III V8 Specific
    Last Post: April 21st, 2007, 11:54 AM
  4. Yet another reason to like New Zealand.
    By mistermike in forum Lounge
    Last Post: March 22nd, 2006, 10:31 AM
  5. Any reason I should not ?
    By RPO_Z06 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 20th, 2005, 08:53 PM
