Results 1 to 9 of 9
Thread: Difference in LTFT's
    Sep 2008
    Default Difference in LTFT's
    Just finished a head/cam/intake project on my 2003 Z06. Start and runs really well at this point. No apparent leaks or anything mechanically suspicious. In logging I see that the passenger side is consistantly running about 10% higher LTFT than bank 1. For example if bank 1 is at 1% bank 2 will likely be 11%.
    Where do I start to troubleshoot? Don't see or hear a air leak or whistle. O2 sensor seems to be switching voltages properly - just has a lowerverage than bank 1 thus adding fuel. Bank 1 average was right at .450 and bank 2 was closer to .380 or so.
    Please give me some ideas or places to test. Thanks!
    Lifetime Member Garry's Avatar
    Jun 2006
    can you switch sensors to rule out a defect?
    Garry Glendown * '17 Fifty 2SS MT * 99 Firehawk Convertible (for sale)
    Sep 2008
    I can but that is a bit of work. Not sure I can swap front O2's without dropping headers. Should I do that or start by looking at plugs or swapping injectors? Somehow I need to figure this out!
    Jun 2006
    yeah, O2 on stock headers are somewhat a PITA to get to on an F-Body too ... I'm spoiled with the Longtubes I have ... maybe someone else has a better idea ... thought it might be an easy thing to try and possibly rule out ...
    Sep 2008
    Quote Originally Posted by Garry View Post
    I actually have American Racing Headers but don't think there is easy access to the O2 on passenger side near starter!
    You did check for leaks at the headers (at the head, and at the collector)...?
    Sep 2008
    Yes I did - no apparent leaks!
    Might be sensor as Garry said... post logs of HO2Sx1 voltages.
    Sep 2008
    Here is the log file!
  1. 09 LS3 TB difference
    By ForcedC5 in forum Gen IV V8 Specific
    Last Post: April 20th, 2010, 12:32 AM
  2. What is the difference between shifting VSS and RPM?
    By odd boy in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 19th, 2008, 06:34 PM
  3. Difference between BEN and AFR MAF calibration?
    By Bruce Melton in forum General (Petrol, Gas, Ethanol)
    Last Post: January 7th, 2008, 07:47 AM
  4. LTFT difference
    By purrvert in forum General (Petrol, Gas, Ethanol)
    Last Post: April 8th, 2006, 01:28 PM
