Results 1 to 10 of 11
Thread: LTFT imbalance between banks
    Sep 2008
    Default LTFT imbalance between banks
    Just finished a head/cam/intake project on my LS-6 2003 Z06. Start and runs really well at this point. No apparent leaks or anything mechanically suspicious. In logging I see that the passenger side is consistantly running about 10% higher LTFT than bank 1. For example if bank 1 is at 1% bank 2 will likely be 11%.
    Where do I start to troubleshoot? Don't see or hear a air leak or whistle. O2 sensor seems to be switching voltages properly - just has a lowerverage than bank 1 thus adding fuel. Bank 1 average was right at .450 and bank 2 was closer to .380 or so.
    Please give me some ideas or places to test. Thanks!
    Nov 2006
    NBO2 maybe dead.
    Is O2 switch point {B4105} 450.00?
    LC-1 WBO2
    Sep 2008
    Quote Originally Posted by mr.prick View Post
    NBO2 maybe dead.
    The O2 switch point is the same for bank 1 & bank 2.
    It is currently set like below:
    CL Mode Bank 1 Bank 2
    0 450.012377 450.012377
    8 450.012377 450.012377
    16 389.992642 389.992642
    24 440.009088 440.009088
    32 499.994914 499.994914
    40 524.986182 524.986182
    48 524.986182 524.986182
    56 524.986182 524.986182
    64 544.992761 544.992761
    Nov 2006
    Try setting {B4105} to 450.00 across the board,
    the older LS1 OS' have mixed values but if you look at the newer
    OS' this table is 450.00.
    If you want to track {B4105} you need a calc.pid and log it's supporting PIDs
    {****.****} = one of the following PIDs GM.DYNCYLAIR_DMA,GM.CYLAIR_DMA,GM.DYNCYLAIR,CALC.C YLAIR
    PHP Code:
    #Units             Low          High      Fmt  Expression
    *CLC-00-018
    None             0             64         0.0
    "lookup({****.****}, 0,0, 4,4, 8,12, 12,30, 16,36, 20,40,24,44, 28,50, 32,54, 36,54, 40,54, 44,54, 48,54, 52,54, 56,56, 60,64, 64,64, 68,64, 72,64, 76,64, 80,64, 84,64, 88,64, 92,64, 96,64, 100,64, 104,64, 108,64, 112,64,116,64,120,64,124,64, 128,64, 132,64, 136,64, 140,64, 144,64, 148,64, 152,64, 156,64, 160,64, 164,64, 168,64, 172,64, 176,64, 180,64, 184,64, 188,64, 192,64, 196,64, 200,64, 204,64, 208,64, 212,64, 216,64, 220,64, 224,64, 228,64, 232,64, 236,64, 240,64, 244,64, 248,64, 252,64, 256,64, 260,64, 264,64, 268,64, 272,64, 276,64, 280,64, 284,64, 288,64, 292,64, 296,64, 300,64, 304,64, 308,64, 312,64, 316,64, 320,64)"
    #Code                      PRN  SLOT         Units            System           Description
    CALC.CLMODE                F018 CLC-00-018     None           Air              "Closed Loop Mode"
    LC-1 WBO2
    Sep 2008
    Set them all to .450 and took it for a spin. The LTFT's were lower than before but still almost a 10% difference between banks.
    Nov 2006
    You are resetting LTFTs after a re-flash, right?
    An exhaust leak could cause problems, try swapping B1 and B2 sensors to see if the inconsistency follows the sensor.
    FWIW my Fbody has about 3% difference between banks.
    LC-1 WBO2
    Sep 2008
    No exhaust leak that I can see. The STFT's log the same as the LTFT's - if the drivers side is +2% the passenger side is +12%.
    Post some logs showing HO2S11 and HO2S21.
    Sep 2008
    Here is the log file & tune!
    Sep 2008
    Any feedback after posting the logs? I am thinking I have a lazy O2 sensor....
  1. E38 LTFT banks 1&2 differences and p0420 code
    By icetraxx in forum E37, E38 & E67 PFI ECM's
    Last Post: May 6th, 2010, 03:44 AM
  2. EFILIVE conflicting with BANKS PDA...?
    By BJJ-DURAMAX in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 4th, 2010, 11:43 AM
  3. Banks iQ & EFI Live ????
    By Spuco in forum FlashScan V2
    Last Post: January 2nd, 2010, 01:16 AM
  4. EFILive and Banks Ottomind6
    By Schweinmesser in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 19th, 2008, 08:24 AM
  5. LTFT's Banks different
    By heavyfoot in forum General (Petrol, Gas, Ethanol)
    Last Post: August 26th, 2006, 11:48 AM
