Results 1 to 4 of 4
Thread: Help with N20
    Oct 2006
    Lightbulb Help with N20
    I'm have a friend with a 99 Camaro LS1 Automatic. converted to an 2002 os
    The tune that is on it right now is very good, compared to the stock one. He loves it, but now he bought a 100HP wet kit.
    So I guess the best thing is to change to Cos5. but I have no idea how much timing to pull and from what areas. Any ideas
    Attached is the current tune
    Thanks,
    Josh
    90% of people are fools
    9% of people are somewhat smart and depend on the
    1% that know how to use EFIlive.
    Bump for you.
    Feb 2008
    seems nitrous is a little tuffer to tune then I though it would be.. Have you figured out anything yet?
    Texas speed ls2 402, performabuilt 4l60e, 3600 stall,
    Zex Nitrous kit, BMR Torque arm,BMR LCA'S, Relocation brackets.
    best time all motor 11.8 with a 1.6 60' at 6800' DA.
    You may have to research what other people are running their AFR and timing at.
Tags for this Thread
