Thread: Help setting up LC1
    May 2009
    Default Help setting up LC1
    Im trying to input the values from the download section into my LC1 to program it to work with efilive. Im using LMprogrammer 3.22 and on the site it shows version 3.06. Heres my problem.......I click on Analog 1 out, select use air fuel ratio then try to enter these values .883 volt at 10.00 AFR
    4.21 volt at 20.00 AFR
    It wont let me enter 10.00 or 20.00 for the AFR value. I keep getting an error message and this is what it says
    AFR must be between 860.05 and 2619.71 and smaller than upper AFR limit.
    What am I doing wrong? Since im using a newer version of the LM Programmer is there different values that I need to enter? I called Innovate and the Tech guy tells me it should work fine? Please help!!
    Nov 2006
    There is an option for AFR and Lambda,
    Make sure you have AFR selected.
    The minimum and maximum numeric values need
    to be in a specific range for AFR or Lambda.
    IIRC
    7.35 - 22.39 for AFR
    0.5 - 1.52 for Lambda
    LC-1 WBO2
    Oct 2006
    ^^^^What he said^^^^^
    You are not in AFR but Lambda .
    2006 Trailblazer
    May 2009
    Hmmm, Im sure that the 1st thing that I did was click the "use air-fuel ratio" tab.....Ill have to double check.
    Nov 2006
    10.00 afr = .068 lambda
    20.00 afr = 1.36 lambda
    LC-1 WBO2
    Oct 2006
    Quote Originally Posted by Slow73 View Post
    You are checking the AFR and then saving it first , reopen then set values ?
    What firmware version ?
    2006 Trailblazer
  1. Setting up V2 for BBL...
    By joecar in forum Black Box Logging
    Last Post: May 2nd, 2011, 01:41 PM
  2. Help setting up AEM WB
    By SUPERTRUCKER in forum General (Petrol, Gas, Ethanol)
    Last Post: April 18th, 2009, 10:22 AM
  3. Setting up A0014
    Last Post: April 7th, 2008, 02:00 PM
  4. fan setting for ls2?
    By minytrker in forum Gen IV V8 Specific
    Last Post: June 15th, 2007, 03:45 AM
  5. Setting up PLX with V2
    By mtnman in forum FlashScan V2
    Last Post: February 8th, 2007, 07:20 AM
