Ross,
Can you look at these 3 tables, B1112, B1113 and B1114, Looks like the rows and columns are switched and missing Nm/Ft-lbs for the Units or Description.
That's what the LBZ tune file looks like with build 88 or am I??
Ross,
2011 LML 3500HD CC D/A 4x4
2006 LBZ 3500 CC D/A 4x4 Sold
2001 LB7 2500HD D/A 4x4 Sold
I just tried to change it up in the cal.link.txt file and that didn't fix anything. just changed the labels but didn't swap the rows and columns. Sounds like something for Ross
Any update?
I think the tables in the editor are fine except I have defined the torque units to the wrong axis, this is why it shows blank units. I will fix that for the next release too. Once that is done the cal_link file should also work fine.
