Results 1 to 1 of 1
Thread: E38 VSS output
    Apr 2008
    Default E38 VSS output
    Important question to the E38's VSS pin:
    if H0159 is activated, can I adjust that output with H0105 and is H0105 only acting on the ECM's VSS output ( I think pin 57..) and not on all the other VSS values on the GMLAN?
    If nobody has done it before, somebody has to do it....
    1997 Tahoe 2dr 4WD
    2002 Alfa Romeo Sportswagon 2.0 JTD
    1982 Deutz Intrac 2004A
    2003 friesian Horse " Henry"
  1. LBZ DSP Output?
    By sp6c170 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 30th, 2009, 09:41 AM
  2. DSP Output changes
    By GMPX in forum Duramax LB7
    Last Post: November 12th, 2009, 01:43 PM
  3. LC1 AFR output numbers
    By 1bar in forum General
    Last Post: March 23rd, 2009, 10:31 AM
  4. E-38 Tach output
    By MSURacing in forum Gen IV V8 Specific
    Last Post: February 10th, 2009, 06:45 AM
  5. WB output and 24 channels for V2
    By 02Z06 in forum General
    Last Post: May 18th, 2008, 03:49 PM
