I got my 30# SVO injecters in and my LT headers, car is a 99 z28 auto with bolt ons. should i change anything in the tune for the injecters and headers or just leave it stock?
You definitely need to make changes for the injectors.
LC-1 WBO2
Car seems to run great without tunning with the injecters in...what would u suggest I change?
its probably only running okay because your O2 sensors are dumping in a bunch of fuel to compensate for the incorrect info in there. you need to at LEAST make sure your IFR (injector flow rate) table is corrected. any other info you have on your injectors that you can put in will just make the fueling calculations that much more accurate.
Recalculate your IFR, then go for a spin and see what your LTFT's are, post logs.
Like Joe says the IFR should be checked so I posted the calculator.
You need to know the PSI or KPA and the LBs per hour the injectors are rated at. Punch in you numbers and there you go.
Down load it fist and try it.
I did not do the work but I found this I am pretty sure on this forum and you have to have this if you are changing the injectors to other than stock.
98 tigershark
98 tigershark
L92/427 w/L76 CC'ed heads n upgraded springs
4.100 stroke, 4.068 bore w/ 11:1 comp
Cam, 591 int, 613exhst, 232-246dur@.050, 115*
LG headers, High flow cats,
RPM level 5 trans, RPM 3.42 gears, 2800 rpm trq convrt. .
Special Thanx to Joe and Bruce!
