Results 1 to 7 of 7
Thread: DSP Output definition
    Default DSP Output definition
    Hi Ross
    Would it be possible to add to it (again) in the next update? Some of us want to restrict the DSP output signal to only one DSP position, for example. Is it possible to logic that in? 1,2,3,4,All
    Would love it also if IAT min/max was added. Help prevent people from icing up their turbo's, etc.
    THANKS!!!
    Custom Tuning Services
    I'll have to think about a nice way to implement that, currently of course it only checks for non DSP and DSP {A0015}.
    I have changed the output control parameters to this -
    {A0115} DSP Output Enable, DSP Only
    {A0116} DSP Output A/C Enable
    {A0117} DSP Output RPM Enable
    {A0118} DSP Output RPM Disable
    {A0119} DSP Output Boost Enable
    {A0120} DSP Output Boost Disable
    {A0121} DSP Output Coolant Enable
    {A0122} DSP Output Coolant Disable
    {A0123} DSP Output Max Speed
    {A0124} DSP Output Min Run Time
    Confirmed working on at least one truck.
    Icing up the turbo, makes me think of a Top Alcohol dragster on a cold night.
    The IAT is actually for water injection. It is a key parameter for dosing and for estimating saturation. One of the more effective ways of inhibiting injection to save fluid.
    On the other detail, the idea is that meth or nitrous could only be used for the specific DSP tune that is built for it.
    May 2006
    Thumbs up What he said ^
    2X
    2001 K2500HD Duramax/Allison
    No problem, I can add IAT in the same as the other enable/disable parameters, better to say something now, I've only done one OS for testing so far.
    I looked at doing the Output vs DSP number, it gets messy.
    First thing, there is time constraints on the CPU, we are adding in an additional function for it to perform within a very specific time frame, I don't want to risk the CPU not completing the DSP Output task by making it do too much.
    However, that is not the main issue. The DSP tunes are tracked in the ECM memory as real numbers, 0,1,2,3,4. If you want the output to only come on using Say Tune 0 & 3 it makes it rather messy to handle in the checking routines.
    If the DSP tracking was a bit select then it would be easy, but I am not about to change that at this late stage because I would have to rewrite everything. Besides, it was done the current way for ease of tune selection in the code.
    Oh well, you got the IAT at least!
    Thanks, understand.!
  1. MEFI 4 ECM definition file
    By blazerdude in forum EFILive V4
    Last Post: May 10th, 2016, 01:33 AM
  2. Need definition for 16197427
    By serial_killer in forum EFILive V4
    Last Post: October 7th, 2009, 08:59 AM
  3. Additional PID definition ?
    By gmh308 in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 24th, 2009, 12:05 PM
  4. Custom/DIY calibration definition file?
    By jimter in forum General (Diesel)
    Last Post: October 10th, 2007, 09:25 AM
