when you go into the LC1 software to setup the voltage on analog 2 out for flashscan, what is the correct voltage per AFR?
is it:
.5 volts = 10 AFR
4.5 volts = 18 AFR
I got those numbers from a write up on here I believe.
I have a problem getting flashscan to read the same AFR as the gauge I have.. the gauge would show 14.5-15.5 AFR at idle and flashscan is showing 15.5-16.5 AFR at idle..
I'm about 99% sure the gauge is right, it was setup by Dynotune as a direct plug in.. the factors for it were 1 volt = 10 AFR and 2 volts = 20 AFR, I had to change it to run the LC1 with flashscan.. but, are the voltages correct?
