Changed everthing to imperial to eliminate mistakes and had to add extra columns on the ben map (rpm vs psiHg). I extended the columns to 23.6 to catch all the data. Now this will not match my VE map when I want to paste and multiply. The columns on it only go to 15.2. Can my manifold pressure be this low with a big cam? Or is my understanding wrong? PID units are set to imperial also.
