Texas speed ls2 402, performabuilt 4l60e, 3600 stall,
Zex Nitrous kit, BMR Torque arm,BMR LCA'S, Relocation brackets.
best time all motor 11.8 with a 1.6 60' at 6800' DA.
1999 Trans Am. 10.71 @ 126 - stock bottom end-
What is your max injector duty cyle at WOT without the spray? Since you are running a wet shot they only need to be large enough to cover this condition.
The Tremor at AIR
Here is a log without spray, I ran it to check timing.
That log shows your injectors should be fine.
A few more questions though. Why are you commanding so rich an AFR under WOT conditions? Does your actual/commanded AFR match when running N/A? Where are you getting the fuel supply for the nitrous shot? Fuel rail or stand alone?
The Tremor at AIR
the wideband says i'm at 12.8 afr. I just had it tuned by a guy who tunes lsx motors pretty well. lsxtune.com I'm using the fuel rail for the fuel. I think I will change the fuel pump this weekend see if that helps..and will move the spray location. the guys who tuned used hptuners and we had the wideband hooke up with it so he can see what its doing. I really want to thank you for all your help..
is there any way I can have the tune add more fuel ?
I dont want to sound like an ass here, but you are lucky that the maf frequency was pegging & causing the PCM to enter Speed Density mode. There is only some timing taken from a small area in your high octane table between 0.60-0.80g/cyl. If SD mode hadnt been hit, which will make the pcm use the low octane table, you would have been commanding 28 deg advance all the way to 1.2g/cyl. Possibly causing some serious engine damage.
Personally, I would be starting from scratch & getting your N/A airmass model right before spraying.
The Tremor at AIR
Ok thanks for taking time to help. What should I work on first with the na mass? I thought it was pretty good but shows what i know... any advice?
