Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 68
Thread: nitrous help
  1. #21
    Oct 2006
    Quote Originally Posted by blue99ta View Post
    Ok thanks for taking time to help. What should I work on first with the na mass? I thought it was pretty good but shows what i know... any advice?
    IMO the first thing to do is get your wideband logging into Efilive. If you have the V2 unit the best way is to get a serial cable from TAquickness. If you have the V1 you will need to go from the EXT.ADx analog ports with the supplied cable(if they ship one with the lm-2). Once this is done you will need to ensure that your IFR table is correct for your injectors & rail pressure & then go through the AutoVE & Automaf procedures.
    Fuel supply definately seems to be a problem so you will need to check that out as well. Logging fuel pressure is a good way but it costs a few dollars to set up.
    The Tremor at AIR
  2. #22
    Feb 2008
    how do I tell what version of efi i have?
    i think i have v 7
    How do I get ahold of taquickness?
    Texas speed ls2 402, performabuilt 4l60e, 3600 stall,
    Zex Nitrous kit, BMR Torque arm,BMR LCA'S, Relocation brackets.
    best time all motor 11.8 with a 1.6 60' at 6800' DA.
  3. #23
    Lifetime Member waterbug1999's Avatar
    Mar 2008
    i think i have v 7
    shoot him a PM.
    1999 Trans Am. 10.71 @ 126 - stock bottom end-
  4. #24
    Oct 2006
    i think i have v 7
    V1 or V2 is the flashcan device. V7.xx is the software. If you have a look at the heading on this forum V1 is the one on the left. V2 on the right.
    The Tremor at AIR
  5. #25
    Feb 2008
    Ok I think I have found out what the problem is. I took the fuel solenoid apart and cleaned it. I then with the car off and nitrous off hit wot. the fuel sprayed out like crazy, before I cleaned it it wouldnt spray much at all. Now I run a 12.4 with the .033 back in. So now I'm going to ordr a fuel filter and try again. Thanks for all the help!
  6. #26
    Mar 2008
    you moved your nozzle AFTER the MAF now right?
  7. #27
    Feb 2008
    going to this weekend..
  8. #28
    Mar 2008
    I still cant believe you are spraying a wet shot before the MAF... You should get the Nirto Daves plate, its a nice piece.
  9. #29
    Oct 2006
    Quote Originally Posted by waterbug1999 View Post
    I agree. At a minimum I would ensure that the timing is pulled right up to the 1.2g/cyl limit. In that log you posted you can see the first hit of the gas run up to 28deg advance. Luckily the P0103 code set before the second hit or damage could have been done to the engine.
    The Tremor at AIR
  10. #30
    I'm no expert, but I agree with what 5.7ute and waterbug1999 have said.
    Log DYNAIR and DYNCYLAIR; get rid of some other pids (get channel count to 24 or less).
    HO2Sx1 voltages indicate you're lean (altho do not rely on those, get a wideband or two).
    If you have a wet plate before the MAF, then the MAF getting wet will cause it to misread.
  1. Nitrous COS for 2006 E40?
    By KAZ MotorSports in forum Gen IV V8 Specific
    Last Post: May 23rd, 2008, 03:51 PM
  2. 75 shot Nitrous Dry
    By oztracktuning in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: February 21st, 2008, 11:43 PM
  3. Nitrous Control
    By Kevin Doe in forum General (Petrol, Gas, Ethanol)
    Last Post: December 20th, 2007, 09:59 AM
  4. 2 tunes for on/off nitrous ?
    By Boost in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 5th, 2007, 01:53 PM
  5. Nitrous controller via the pcm?
    By wait4me in forum General (Petrol, Gas, Ethanol)
    Last Post: June 6th, 2005, 03:15 PM
