Results 1 to 10 of 12
Thread: 2002 8.1L
    Oct 2005
    Default 2002 8.1L
    Is this supported with the newer versions of the scan tool I can connect but don't have the ability to do anything with the scan tool once I am connected.
    Lifetime Member SinisterSS's Avatar
    Sep 2003
    Yes, your 2002 8.1L is supported. Sounds like you may have a licensing issue. Have you entered your information off the "blue card" correctly?
    2009 Z06 LS7 / 2008 Sierra Denali AWD L92 6L80E
    Flashing control modules since 2001. 8-)
    Who needs a MAP sensor on a supercharged LS6 anyway.
    Oct 2005
    I just updated from my version 5 and did the copy paste in the liscense field it connects to F-body's without a problem.
    Does it connect to the 8.1?
    If so, is the red "log data" button on the toolbar at the bottom of the window enabled? (i.e. not grayed out)
    If so, click on the red "log data" button.
    If you get to a point where you can't go any further, press Ctrl+G (Or select menu option File->Generate error report, and save the error report and email it to me at paul@efilive.com
    Oct 2005
    E-Mail sent.
    Quote Originally Posted by 94SS
    E-Mail sent.
    Got it thanks.
    Oct 2005
    Paul,
    When you figure out whats going on, LET ME KNOW! I installed the newest pre-release like we talked and I am still having the same problems.. although this is a late 05. The 05's and 02's are the only ones I have trouble with.
    Dennis
    Air Flow Development
    717-887-4666
    E-Mail sent.
    Got it thanks.
    Looks like it is not recognising the cable as a registered cable. Do you have more than one cable? Strange that it connects to F Bodies and not the truck.
    When you try to connect have you checked for any messages in the [Console (F12)] tab page? If there are any messages that indicate a problem, please copy/past that info to me via email at paul@efilive.com
    Thanks.
    Oct 2005
    any new developments on this problem?
    Dennis
    Quote Originally Posted by airflowdevelop
    Dennis
    Feel free to send me the same info I asked of 94SS.
  1. 2002 PCM pinout
    By pjaneiro in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: February 10th, 2019, 12:13 PM
  2. RAFIG on 2002 Z06
    By Kevin Doe in forum Gen III V8 Specific
    Last Post: April 21st, 2009, 03:42 AM
  3. L59 for 2002 VIN Z?
    By Lennart in forum Gen III V8 Specific
    Last Post: December 10th, 2007, 02:03 AM
  4. 2002 T/A
    By sdf8 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 28th, 2005, 08:04 AM
