Results 1 to 6 of 6
Thread: Having some problems...
    Jul 2009
    Default Having some problems...
    Hey all, I downloaded the eval version recently under hopes to get it to work and I am considering purchasing the full version if i can get this to work right.
    Now, I'm sure this is a simple problem with a simple solution...but I dont know it...
    I'm getting this in my log
    22:58.591: Initialising...
    22:58.989: Opening COM3 8228,8,N,1
    22:59.000: setCommState() failed for Com3. The parameter is incorrect.
    22:59.153: Ready.
    What do I do? I keep getting that setCommState() failed for Com3 and can't get it to go away no matter what I try.Thanks in advance for helping out a noob.
    Are you using a USB-COM converter? If so then the problem is most likely the converter does not support the (non-standard) ALDL baudrate. I.e. 8228, which is the closest the PC's UART can be programmed to the real ALDL baud rate of 8192. Try using a laptop with a real serial port.
    If you are using a real serial port, make sure that COM3 actually exists and the the interface is connected to it. If the interface is connected to some other COM port then change the EFILive settings to the appropriate COM port.
    Jul 2009
    I'm using the USB cable from aldlcable.com
    The thing that has me stumped though, is that I downloaded and used efilive eval successfully when I first got the cable. I didn't have any problems with it then and was able to connect easily. I had to reformat my computer since and haven't tried to use efilive until now, and now this problem is arising.
    The vehicle is a 1993 Pontiac Bonneville SSEi and is the same one that I used the program on before. What could cause it to work before but not now?
    Probably because after you re-installed windows the COM port changed so that it is no longer COM3. Try this:
    1. Right click on My Computer and select Properties.
    2. Select Hardware->Device Manager
    3. Expand the "Ports (COM & LPT)" entry
    4. Look for the USB cable and double click it (or right click and select properties).
    5. Go through the settings until you find something that defines which COM port it is hooked up to. There may be a setting to lock it to that COM port permanently - if so I recommend doing that.
    Then start the EFILive software and Select Edit->Properties->Comms and select the correct COM port for the ALDL cable.
    Jul 2009
    Success! Thanks for your help Paul.
    Now that I have this solved, is there a write up or directions anywhere of how to make a definition file for my car, I'm not sure if any of the available ones will work for me perfectly.
    Jul 2009
    Never mind, did a little reading here and found that there was the right definition file in there for me. Awesome
  1. Help problems......
    By VACARELLAB in forum Duramax LB7
    Last Post: April 14th, 2009, 12:16 AM
  2. V2 problems
    By GAMEOVER in forum FlashScan V2
    Last Post: January 17th, 2009, 01:05 PM
  3. 2 problems
    By 1fastgto in forum Gen IV V8 Specific
    Last Post: December 26th, 2008, 05:27 AM
  4. Serious problems again - please help
    By Boost in forum Gen III V8 Specific
    Last Post: September 10th, 2007, 12:12 PM
  5. lc1 problems
    By woody69 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 3rd, 2007, 07:39 AM
