Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: 98 PCM for Z28
    Lifetime Member 87gmc's Avatar
    Apr 2004
    Default 98 PCM for Z28
    So how far along did the software get for the 98/97 year models. Will we be able to tune this computers?
    Chris
    Aug 2004
    i have a list of all hex locations for everything, would this help the cause?
    Oct 2003
    Indeed, it will definitely help a lot.. Can you get me a copy? We're about to start putting together the 98 cal ...
    Aug 2004
    i have it all scibbled out on paper, just give me a form and ill complete all the hex locations for that perameter. .
    Oct 2003
    Whatever is easiest for you. I'd take it in Excel or raw text file if you want to send it that way. As of this second, I don't have a specific format for you to put the data in. I'd kinda feel guilty burdoning you to put it in a specific format anyway Heck if you don't feel like keying everything, take a scan or good resolution digital cam pic of the sheet and email it to me.. I'd be happy to do the grunt work.
    Aug 2004
    ok, ill go threw it all and make a text file, will this be spelled out enough or do i need to go in depth and set up all the boundrys?
    operating system 9375577
    idle speed vs coolant temp in gear ac on, off in neutral ac on and off
    offset 464354 to 464482
    and also verify if this is correct so i am not wasting your time and mine,
    Oct 2003
    That's perfectly fine, I can figure out the axis and scale pretty well when it comes time to put it in the calibration file..
    BTW - Thanks in advance for the help, from all of us '98 guys 8)
    Aug 2004
    is that offset information correct? im just making sure, i have the whole pcm output for every os and just about every year and make of car. yes i was bored.
    Apr 2004
    Thanks from a 98 guy here
    Apr 2004
    Any progress on the 97/98 pcm?
