If you have enough people interested in a class down under, I'm game. Contact me offline and we can sort out the details.
~Greg
Calibrated Success - EFI Training and Tuning Done Right
GM Beginner's Guide DVD available now through Summit!
Engine Management: Advanced Tuning - Amazon's best deal for the EFI crowd.
Thanks, Greg. Nice to see you over here. You're in a great position to unify the GM tuning community around common knowledge, rather than the sectarian bickering over software that often obscures what we're really trying to learn. Perhaps you should collaberate with Ben Strader on a translation manual for tuning jargon. J/K. Best of luck with the new book and video.
World's First Twin Screw Pontiac GTO
2004 GTO. Blown H/C 408, stage 3 keyboard, billet tires
2017 Chevy SS with dead hooker is spacious trunk
2014 Chevy Cruze. MPG queen with my balls in spacious glove compartment.
www.aussiemotive.com
I'm not sure I follow you here. What is missing with regards to "tuning jargon"? My new book will have a glossary of commonly used terms in it, but nothing that program specific like "RAF = running air flow" or "{B000x} = this specific tuning table/parameter in EFILive" since other manufacturers don't use anything like that and it would make for a very narrow scope that doesn't sell many books. It does however define RBT, LBT, Lambda, DFCO, phi, and other commonalities used in both standalones and OE controllers.
~Greg
Dude , I think Summit messed up on the price because it says $249.95 , shouldn't it be $24.95 ?
Does the DVD come with a cable and controller as well ?
How many licenses ?
2006 Trailblazer
I was only half serious in making that suggestion. While there are few significant differences in available parameters between HPT and EFI Live, or standalone controllers for that matter, the jargon in the HPT AND EFI Live communities seems to have evolved independently, and sometimes results in confusion for those not intimately familiar with the "other" tuning package, whichever one that may be.
right on Greg, I read your advanced tuning book and its a great rescource. I'd love to see what your DVD contains.
when you say that you have info on injectors, does that include tables such as injector voltage offsets (i.e. Dead times)? and unless I'm mistaken, ford and gm use different ways of displaying and calculating the voltage deadtimes so simply using ford data in the gm tables wouldn't work correctly, do you go over differences like this in your DVD for people who are looking to use ford or other non-gm brand injectors?
great to have you on the forum man.
I'm intimately aware of the differences in injector characterization methods between Ford and GM. The DVD includes a CDROM data disc with MSExcel format files that have the properly converted data for use of the FRPP injectors in a late model GM vehicle. The data includes offset vs voltage (and MAP) tables, short pulse adjust values, as well as corrected flow rates for the GM 4bar working pressure.
This is a big part of the "behind the scenes" engineering that had to go into place before releasing the DVD. It's also big portion of why the cost is $250 (Summit has it right). Keep in mind that you're also buying professional training here not just some backyard mechanic's how-to guide. I spent a LOT of time putting this knowledge together and have previously only shared it with those who signed up for one of my classes that start out at twice the price. This disc delivers real knowledge that is only currently available from much more expensive sources such as live classes or real world experience as a calibrator on an OEM or high-end aftermarket company. This disc set is far cheaper than your first damaged engine and will go a long way toward making your life easier as a tuner.
Mike, I agree on the parallel paths of "jargon". I too get confused when people on either forum start abbreviating too much or calling out table numbers instead of functional names. When I post, you'll see that I typically call a table or parameter by its functional name (e.g.: "VE table" or "idle airflow table") rather than a precise name or "B" number because these are subject to change from year to year or program to program. My intent is to make material and posts that many people can learn from by using common terminology whenever possible.
~Greg
