Can you perform a VATS relink with scan only?
I'm trying to swap PCMs with a scan only interface and RR,
with no luck.
Who is using a RR with scan only and Bluetooth.
with no luck.
LC-1 WBO2
I swapped RR's and,
yes you can do a VATS relink with scan only.
I had to remove the internal battery to reset the RR.
LC-1 WBO2
