If that will correct all the values below full throttle as well, I will give it a try. I assumed it would only cap the max. Is that not true?
I appreciate the help.
Custom Tuning Services
Have you logged all of the TQ PID's at the same time. there are about 4-5 of them. some in the TCM and some in the ECM. Between the 4 none of them match each other.
I really do think the answer to your problem is in limiting the fuel based on TQ not limiting TQ based on APP.
ALSO, One big thing i just thought of. Are ALL of your logged values and values specified in the tune in the same units? I'm pretty sure the default values while BBL'ing a TQ PID is in Nm, and depending on how you have setup you tune tool for that tune you may have your units in Ft/Lbs?...
Both B1115 and B1102 show ft-lb as units. Good thought. The log shows ft-lb also.
I have only logged the one tq pid since it is the one referenced in B1102
If I understand your suggestion, I should log all throttle pids, and change the cal_link, for each of them, to see if any of them make more sense?
Have you change the linked axis to TP_A?
can't hurt at this point. I will try this. However, it does not look like I have a TP_A option. Several others though.
Using V7.5.5
For an LBZ?
Are you BBL'ing or using the laptop?
Laptop
