Results 11 to 20 of 31
Thread: IAT2 or ???
    Feb 2007
    I believe it is also called that in BBL. If you want to verify it is the correct one, unplug your temp sensor where it goes over your turbo mouthpiece. IIRC, it should read -40 F when unplugged.
    Jan 2008
    Well SAE.IAT is the one that is measured at the MAF (pre-turbo) Dunno whats going on with this IAT2
    Feb 2007
    Quote Originally Posted by bballer182 View Post
    Hmmm, I guess I was remembering wrong.
    Jan 2008
    I'm also having trouble with the VSS from the TCM also. It reads zero all the time. Does anyone else's work?
    Feb 2008
    FWIW..
    IAT is with the MAP sensor pre turbo on the LMMs.
    IAT2 is in the Y bridge on the LMMs. IAT2 is a seprate sensor (looks like a EGT Sensor)
    I can only assume LBZ is the same.
    12 Second LMM
    Jan 2008
    Quote Originally Posted by MMLMM View Post
    FWIW..
    I'm beginning to wonder if this is an LMM thing and not an LBZ...
    It does continue to confuse. IAT appears to be dampened on the LBZ I am testing. It suggests it is not being measure at the MAF.
    Is there confirmed temp signal at the MAF (06-on)?
    Custom Tuning Services
    To resurrect an old thread.... The Tech2 shows an IAT1 and IAT2 under "Engine Data 1". IAT 1 is cooler than IAT2. I've confirmed this on a running LBZ. So they ARE both there in teh data stream from the ECM. Any thoughts Ross?
  9. #19
    can you throw up a log, with both shown, a 30 second high load log (use brakes) with AAT, IAT, and IAT2. IIRC, IAT is going to be a dampened slow rise (CAC heat soak) suggesting location post CAC.
    If my hunch is correct, IAT is going to be pre-egr, IAT2 will be post egr.
  10. #20
    Feb 2008
    IAT2 will be quite a bit hotter under pressure (boost pressure).
    IAT1 will be hotter than ambient as its read right next to engine.
    IAT1 is ambient + what ever under hood temp is changing it to.
    IAT1&2 should be about the same crusing with little or no boost.
    12 Second LMM
  1. IAT2 on LMM?
    By forcefedjunkie in forum Diesel
    Last Post: March 31st, 2010, 11:17 AM
  2. IAT2 - LBZ vs LMM
    By Cougar281 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 27th, 2010, 03:16 AM
