So I've done my first AutoMAF log. The 2700-3300 range of the MAFFREQ/Ben Map kinda scare me.
Just to review my process first to make sure I'm doing it right.
b0120 set to 400 so I'm in PE mode all the time.
b3801 disabled, no LTFT
Logged MAFFReq in addition to my other PIDS
P0101 - p0103 set back to MIL
DFCO temp set real high to disable
Opened Log, then opened the B5001-MAF Calibration - LC1 WO2 BEN.map sample file. Change LC1 to my WO2AFR Ben and voila, my map filled in. See pic. I've also included my tun and log.
So I'm supposed to copy with labels, then paste and multiply with labels over the top of my B5001 right? What about those really high multipliers from 2700-3300?
What does the MAF Calibration LC1 WO2 AFR map do for you?
My car ran decent expect idle at stop got down to 500rpm. Makes you worry your gonna die out. That is probably another chapter later though.
Ken . . .
