Results 1 to 10 of 19
Thread: Invalid PID
    Jul 2009
    Default Invalid PID
    I'm trying to tune my LS1. I'm using a 1220411 PCM with a custom (MAFless) operating system. I get an invalid PID message when I try to look at HO2S21. Any ideas as to what I'm doing wrong?
    Nov 2006
    Have you validated all PIDs?
    Sometimes some PIDs will be Xed out after launching the software
    but will be valid once logging begins.
    Select it anyways and start logging.
    LC-1 WBO2
    Jul 2009
    Thanks for the reply. I have selected it anyway. When I log the data, it flatlines.
    Connect to vehicle and validate pids.
    Nov 2006
    Quote Originally Posted by mk6gtracer View Post
    The PID becomes valid?
    Any O2 DTCs?
    LC-1 WBO2
    Jul 2009
    The PID does become valid, I guess, when I log data, at least it isn't x'd out. Problem is, the data never changes.
    Jul 2009
    The PID for the left bank logs data and oscillates as you would expect
    Nov 2006
    The sensor may be dead.
    LC-1 WBO2
    Post some logs.
    Jul 2009
    I connected the sensor for the right bak, which has and still is working. The value stayed at .250, never fluctuated. I checked continuity back to the PCM, no problems there either
  1. Invalid Auth. code?
    By algz06 in forum FlashScan V2
    Last Post: April 18th, 2010, 09:15 AM
  2. one or more invalid checksum segments
    By SGFastMax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 16th, 2010, 05:22 AM
  3. EXT.WO2AFR1 invalid
    By 5.7ute in forum General
    Last Post: December 29th, 2008, 11:39 AM
  4. Invalid or missing calibration
    By Redbone in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 22nd, 2008, 12:32 PM
  5. Idle PIDs are always invalid
    By Highlander in forum Petrol / Gas
    Last Post: February 28th, 2008, 12:09 PM
